Old 02-12-2020, 05:42 AM   #3
itsnotanova
I've sold 40+ immobilizer,dme and key sets. It doesn't matter if the set is manual or auto. I'm not so sure it matters if it's a 2.7 or 3.2 either but I won't go on record as saying that. You can technically use a set from one on the other. My 2.7 rallycross boxster has a 3.2 ROW tune on the DME. Don't throw away your old set. I recommend holding onto it or selling it. Someone might want to try to fix it or you might need it in the future. If you do decide to use a used set, you don't need to switch out the ignition or door locks. All you need to do is switch the key head or more specifically the transponder pill.
Woody
