Old 02-09-2020, 04:00 PM   #22
maytag
Who's askin'?
maytag's Avatar
Here is a red 987 gt3 bar (TPC i think) on top of my old Tarett 986 GT3 front bar. Except for being slightly wider and the different collar locations, it is the same. I didn't try moving the 986 Tarett to my Cayman (maybe the Cayman needs that extra little wodth) but i doubt that extra width from the 987 bar would hurt going onto the 986, since it has adjustable shaft collars.
Steve, dood, you're such a stud. HAHA. This is PRECISELY what I was looking for.
From the photo, it doesn't appear that there's much (or any) difference in the "lever arm" shape, or length. This was my biggest concern.
So I think I'll probably be okay with the front bar, and just using the shorter tarret drop links.
On the rear, I'm being told that the boxster and Cayman have nearly identical corner- weight numbers, and that this 22.2mm bar is the one I want, as opposed to the 19.1mm that tarret has for the 986. Does that seem to follow your own experience?
