Old 02-07-2020, 04:31 PM   #2
Anker
It could be you clutch assist spring that's broken and gets jammed inside the housing. If you lie down with you head on the floor and look up at the clutch pedal you will see it close to the pivot point. Its a small cylinder. Try pushing the clutch down with your hand and release it while holding a finger on the spring casing with the other. If you feel it click then you have found the culprit!
1941 Dodge Luxury Liner Coupe
