Old 02-06-2020, 08:03 PM   #6
aparke4
I upgraded to the oil filter adapter and have not looked back. I have a oil filter cutter that makes looking a media a sinch. I run a longer K&N Filter... fits great and plenty of room/ clearance to ground below. Filter is still higher than AL oil pan. I run the HP-2006. You can find them everywhere- even at Wally World. Love the wrench off feature as well... run K&N oil features on all of my vehicles for this very reason.
HP-1007 (Stock/ Napa size that comes with adapter)
Height: 3.74 in (95 mm)
Outside Diameter: 2.98 in (76 mm)
Thread Inside Diameter: 0.81
Thread Number: 16.00000
PSI Relief Valve: None
Anti Drain Back Valve: Yes
Style: Canister
Bypass Valve: No
Weight: 0.4 lb (0.2 kg)
The one I use is:
HP-2006
Height: 4.78 in (121 mm)
Outside Diameter: 2.99 in (76 mm)
Style: Canister
Bypass Valve: No
Weight: 0.8 lb (0.3 kg)
aparke4 is offline   Reply With Quote
