Old 02-05-2020, 07:02 AM   #1
truegearhead
truegearhead's Avatar
I assume this was an oversight, when you said "without messing with the suspension geometry". But you will absolutely be impacting your camber. And, likely also impacting your caster dramatically. Unless the elephant racing control arms have the adjustment on the outboard end, but I have never seen that?
The control arms extend and I have camber plates up top which I’ll slide over. So (according to elephant) be able to extend the arms and the camber plates to widen the car without changing geometry (I will be adding leverage on the springs though)
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
