Old 02-02-2020, 01:46 PM   #2
Steelepuls
Flmont, in addition to changing your fuel cap, check for vacuum leaks and I would change the oil cap (mine had a bad gasket causing vacuum leaks). One other item I would check is the oil filler tube, make sure it is intact.
Steelepuls is offline   Reply With Quote
