Old 01-31-2020, 08:04 AM   #1
trygve
FS: Bend-Pak MD-6XP lift (Oakland, CA)
FS: $1500
I'm moving to a space without a garage spot for my race car, so I need to sell my lift.
Due to size/weight, shipping is not an option -- this would have to be picked up at my house in Oakland, California.
It's a Bend-Pak MD-6XP model. Great for a home garage because you can park a car on top of it when not using it, yet for work you can quickly lift it about 4' off the ground. Makes brake & suspension work super easy to access at home. Also the other under car work like oil, transmission fluid. Change a transmission or engine or exhaust. It is a life-changer! The hydraulic power unit (on rolling stand) sits off to the side a few feet away and plugs into a normal 120V outlet.
You need to use ramps (such as the included ramps that I assembled from 2x12 boards) for clearance on any vehicle a Rennlist driver is going to use with it. (Though a typical SUV would clear it.) It is designed to be "portable" because by using the power unit handle you can maneuver it around a garage space should you want to move elsewhere in the garage for some reason. But not something you would want to deal with frequently.
(Note: the current ramps are shown in the last photo. I originally made little stagger-step ramp end attachments but don't have those any more. They are not needed.)
Also: car not included!
trygve is offline   Reply With Quote
