P0442 vacuum leak on the fuel evap system. Check your gas cap. The gaskets are prone to fail.
P1238 check your fuel injector wiring. That code signals a fault on cylinder #2.
P1128 and 1130 means you are running lean.
Check fuel delivery, make sure you have pressure to the fuel rail. Look for damaged wiring related to fuel pump and injection.
It could be a fuel pump, failed injector, or clogged fuel line/filter. That's where I would start looking.
