Old 01-30-2020, 04:01 AM   #11
piper6909
piper6909's Avatar
Originally Posted by dbear61 View Post
Does this occur over all bumps at all speeds? Or do you only experience this on rough roads, not bumps, at low speeds (i.e. <30mph)?
My 2001 S has been doing this at low speeds on rough roads since I bought it in 2012. Seemingly same location, rear passenger side.
I had my mechanic do a thorough inspection, and he could not find any cause. So I just endure it.
DBear
dbear61, your issue is most likely the rear track arms (the tuning forks):
https://www.pelicanparts.com/catalog/SuperCat/1049/POR_1049_SUSSHK_pg4.htm
They're very hard, if not impossible to diagnose while on the car because of the type of joint. Mine had the exact same issue as yours. I changed them and no more clicking/clunking noise. They're easy to change.
This could be the same issue for the OP, if his symptoms are the same.
piper6909 is online now   Reply With Quote
