Thank you! For me, I like to know a bit if the reasoning behind the conclusion. That's a perfect answer.
The PSS adjust-ability comment is kind of what I figured would happen to me. Buy a feature with 1000 settings and set it once. Seems like a waste.
Did you change anything with the sway bars? or just use stock?
Thanks for the info!
*edit*
I assume these are the Struts you're referring to?:
Anyone tried the new Koni FSD struts?
