Old 01-22-2020, 07:11 PM   #2
Jerry1847
My 2000 S has the manual frunk and trunk release levers; a physical cable is used to pull the latch release. The 2001 models use a electronic release (except for the 'emergency' release cables. If you want, I can check my parts shelf to see if I have a 2001 S set that could be traded for your current one. -I need to make sure it was an S model and manual.
I'm thinking the 2000 DME isn't coded for the electric switch. I think the switches are fine, just not wired correctly.
Did the 2000 have seat memory buttons?
Jerry1847 is offline   Reply With Quote
