01-22-2020, 06:06 PM
#10
From the crypt but exactly what I was looking for! Thanks RK.
Originally Posted by The Radium King
so, i did some more looking (cause this is a cool idea). you should be able to widen the track up front with the tpc kit. for the back, the control arm is the same part as the front so you can get that from tpc as well. there are two other control arms that would need to be longer, and both are available aftermarket in adjustable format (tarett, top speed) so should be easy enough to get longer versions. the axle spacers that come with the tpc kit for the front could be repurposed to the back to extend your axles there. next step, if serious, would be calls to tpc and tarett. never worked with tpc, but the guy at tarett is excellent to deal with and would most likely enjoy the challenge. of course, 10" is a lot. is that 5" per side? 2" spacer, 2" wheel offset, 1" wide track mebbe?
