Thanks, no i didnt use a template, what i did was i used white model car paint, then used a brush to paint within the reverse embossed numbers that are already present on the knob, then after its completely dry as a bone, i used a very fine grit sandpaper to sand off any excess paint that I got outside the numbers...pretty much error proof, After Im done with the sanding and im satisfied, I get some armor-all and re-moisterize the surface to bring back the gloss that you lose from sanding it... I think it looks better than stock now that i've done that.
