Old 10-14-2006, 09:58 PM   #1
boggtown
Guest
Posts: n/a
But I will. It is just a circut that is completed by putting the tab in the slot. So try and get a needle and pierce the wire running from the (I don't know the name, but it is where you put the tab) and if you pierce the hot and the ground it should complete the connection and trick it into thinking its connected. Then just get some cutters and cut the ends off and wrap it in tape. I don't know if it will work but the logic is sound. BTW my real name is Jon Smith.
