Old 01-21-2020, 12:47 PM   #14
Hasbro
Just had a very pleasant chat with the design engineer at Vorshlag (when I should be working). Wish I had recorded the very one sided informative discussion. I wanted to see what spring weights the Ohlins dampers can tolerate prior to damper modifications - Ohlins will only build 10n up or down, which would be about 330 lbs front/400 rear. We talked about my two different square tire selections, size, models, and car usage and he felt the springs would work very well. In a nutshell. no charge to change spring weights. I meant to ask him about a wider track and perhaps just staying with the 400/457 springs but that will be another discussion.
Hasbro is offline   Reply With Quote
