Old 01-21-2020, 05:58 AM   #1588
Nine8Six
Nine8Six's Avatar
Originally Posted by Evan_S View Post
What is the (high-temp) glue that you used? Or is there another solution?
Hi Evan, thanks! yes I remember this chap, although I can't recall if those projectors were ever assembled and instead meant as a replacement for another set he had (he had the first ever set in silver if memory serves well!). I'm hoping those came with the H1 bulb mounting adapter and other hardware?
For the lens assembly you need a A+B epoxy rated/tested at 100dC. Surface preparation for both the lens and bezel requires decreasing with a pure acetone before bonding. Assembling and curing should be carried at room temp (indoor, 21dC).
ps. Welcome to the forum! Seen pics in the general section, great looking boxster
