Old 01-20-2020, 06:33 PM   #11
jaykay
jaykay's Avatar
Originally Posted by barthol View Post
Hi Jaykay
It is definitely motor oil on the right side.
My tube looks fine on the flange where it connects into the engine , Both bolts are tight.
Is the leaking pipe normally where it connects to the engine or where it connects to the flex hose going to the filler in the trunk?
Any Ideas on how to get to the front Bolt , it is situated under the Generator ( no room for a socket:_()
BR
Kim
It's the in between pipe and flex hose connection likely...it's been so long since I repaired that I don't recall removing the bolt under the alternator.
986 00S
