Old 01-19-2020, 08:31 AM   #2
Tremonte986
Check around the oil cooler, should be easy to tell if that's the culprit and also run your hand down the flexible oil fill tube. Those are bad to leak where it connects to the engine and will cause puddling where you are talking about. I had that issue and replaced mine during the coolant tank replacement. Just be careful not to wiggle it around too much. The hard 90 that attaches to the engine under the intake can get brittle as well and the ears break off easily. That one is not easy to get to without removing quite a bit of items. A new oil fill tube is ~$25 and fairly easy to replace.
Another point for common leaks is the spark plug tubes. Another easily replaced item to check.
Tremonte986 is offline   Reply With Quote
