Old 01-18-2020, 02:33 PM   #3
seningen
seningen's Avatar
Originally Posted by seningen View Post
That diamond piece that connects the subframe together can be quite the PITA to get on and especially to get back on.
I found if you take a ratchet strap between the two sides of the suspension and squeeze them together the diamond piece can be easily removed and installed.
Mike
I found the back most studs might not line up quite right -- but it's easy to loosen the bolts on that bracket, line up them up to the diamond and then retighten them.
All this might be easier to access because its a race car -- but the same principal should apply to other cars.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
