Old 01-15-2020, 06:19 PM   #11
Porsche54321
It seems like you're pretty comfortable doing that, but I'd be very careful about using a heat gun on it.
I swapped the EEPROM from my damaged one into a replacement unit, but it's not for the feint of heart. There are so many tiny components nearby, and they can easily drift out of alignment from their pads.
I practiced many times on junk boards before I dove in.
To prevent the solder from separating, you can dab some flux on the pins. That should help keep the solder on the pins and pads.
Good luck.
Hmm, how did you know the eeprom was the issue?
Maybe I can just try to apply the heat only to the eeprom with a soldering gun.
Porsche54321 is offline   Reply With Quote
