Old 01-13-2020, 03:22 PM   #4
maytag
Who's askin'?
maytag's Avatar
Originally Posted by Russdawg1 View Post
Hi guys, first post.
I’m looking into buying a 1997 Porsche Boxster, and I was wondering if I could fact check my research.
So obviously these cars have some problems. No argument there. How severe, and how soon it should be proactively replaced is my question.
IMS Bearing - Seems to be the big ticket item. My research has shown that on the 1997 year which uses the dual row bearing, the failure rate is a measly 1%. Im willing to take the 99% chance of a Porsche that will function fine, but will be looking to replace the bearing if and when the clutch needs replacing as its $400 or so for peace of mind. Thoughts?
RMS - This is less important, obviously excessive leaking is bad, but replacing it is only laborious and the seal is like $20. If it is barely leaking or not leaking at all, I am golden?
Cylinder liner - Someone had said that this was a problem only in 1998, the first 1997 year, didn’t have this problem, and it was addressed in the 1999 year on.
Checking for oil emulsion and/or coolant mixing. If I see this, is it fixable? I wasn’t able to find too much on this. All I’m aware of is if I see the mayo of death around the cap, find a new car to purchase.
Coolant leaking in the back (damp or wet trunk area) - New tank is $600 or so, knock that off the price and still purchase?
Anything else I need to be aware of? Most of my reading has led me to believe that this is a fabulous car other than these problems, which are generally quite expensive and would be extremely deterring if it wasn’t for the fact that it’s labor that costs the most, not the part. I can supply free labor
Thanks!
You're on the right track here.
However......
The prices you're quoting for the couple of items lead me to believe you're planning to pay somebody else to do these repairs? ($400 for the IMS when already open for Clutch and $600 for coolant expansion tank)
If that's the case, you get my standard answer to these posts:
If you are planning to PAY SOMEBODY ELSE to work on your 20-year-old car, then a car with a $225 shop-rate probably isn't the right one. Or more pointedly: Don't buy a 20-yr-old-porsche unless you're a DIY-er.
YMMV, BPW.
maytag is online now   Reply With Quote
