Old 01-13-2020, 10:14 AM   #19
Nine8Six
Nine8Six's Avatar
Originally Posted by Kboggs View Post
I had the small mono amp already to use for just the door subs. Figured while i was in there just get rid of the factory amp and use a larger 4 channel amp for the fronts and rears. Im trying to talk my wife into letting me try out a larger sub in the frunk.
Gotcha on the amps. Sub in the frunk won't work I'm pretty sure, freq will be absorbed by the body more than anything and you'll end up with a nasty humming all across. Unless you drive this at 25+ Amps/current then, dunno, could be fun
See if you can fit one of those low-profile 8" sub, e.g. Kicker w/ built-in 150W Amplifier. Just shim the passenger seat +1 inch up and be done with it (I'm only guessing here).
ps. that cabin is pretty damn small, watch out for the high dB for long duration bro
