Old 01-11-2020, 11:08 PM   #744
Nine8Six
Nine8Six's Avatar
Originally Posted by bg305 View Post
Just curious, if you wire up the brake connection can you still just use the LED in any color?
Is it:
A. Off until you press the brake then red when you do
B. Default color until you press the brake and then red when you do
Is there a switch on the control box to the the brake mode on and off?
-Brian
Answer is "B". It will ship like so as default
Although, we want this to be programmable so if someone wants "A" and use it as 3rd brake light either myself of the user can re-write the firmware with that specific feature enabled. I'll have a full tutorial on how to do this later on, no worries!
Regarding the option to have the brake signal input (or not) see inputs below. E.g. if you do not want the brake light to sync with the SkyBreaker just omit the Brake Signal line to the controller.
