Old 01-11-2020, 03:50 PM   #11
bg305
01 Seal Gray 986 S
bg305's Avatar
The brake feature is optional of course, just omit the extra connection.
Just curious, if you wire up the brake connection can you still just use the LED in any color?
Is it:
A. Off until you press the brake then red when you do
B. Default color until you press the brake and then red when you do
Is there a switch on the control box to the the brake mode on and off?
-Brian
bg305 is offline   Reply With Quote
