Old 01-10-2020, 10:09 PM   #19
The Radium King
The Radium King's Avatar
ride height and top mount position in the slots will impact max camber as well. camber plates will get you additional camber. not sure why your caster is off; the thrust arm bushing options are all pretty similar across vendors and caster should not be out that bad? regardless, adjustable thrust arms will solve it.
