Old 01-10-2020, 03:22 PM   #2
truegearhead
truegearhead's Avatar
Originally Posted by Qmulus View Post
Well, first off the block will NOT bolt up to the Boxster transmission. The RS6 block is different than all of the other Audi V8s in that is was made to accommodate a larger bellhousing necessitated by use of a larger torque converter to handle the torque of the twin turbo V8. People that have done manual swaps in RS6s need to use an adapter plate and get a special flywheel, as the RS6 crank has 10 flywheel bolts vs. the normal eight on other Audi engine that have manuals.
That is the least of the worries putting one of those in a Boxster. If you have ever seen the packaging of the engine compartment in an RS6, you wouldn't even consider putting it in a Boxster. They are truly nightmarish. It is hard to fit 2.7T in a Boxster. I can't imagine trying to fit an RS6 engine in one. If you want that kind of horsepower, a LS engine would be a much easier and likely lighter swap.
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
