Old 01-10-2020, 06:27 AM   #2
Starter986
1998 Boxster Silver/Red
Originally Posted by truegearhead View Post
OK, stay with me here. An audi 4.2L C5 motor will bolt up to a Boxster transmission and is a proven swap. The same generation C5 RS6 bi-turbo (which does not share the same block) can be swapped into the 4.2L C5 motor with the same 4.2L C5 transmission so I assume it can be bolted onto the Boxster transmission as well. Looking on eBay these motors are around $3-4K, and have 450hp out of the box and with a chip can generate 510+hp. Of course a turbo motor is much more complex but still a very cool swap idea. Someone go do this
OK. You've got my attention.
I've read posts that suggest a true just-bolt-on... but am left wondering: is this bolt-on to a manual transmission and/or the Tiptronic? Pardon my ignorance, I don't know everything.
Also... I'm assuming there would be some retrofitting? Motor mnounts... moving some electrical and cooling lines?
Finally, can the rest of the car handle the 450HP? You know... not torquing the **************** out of anything?
Thanks!!
1998 Porsche Boxster
