Originally Posted by Wallace River
Good god this is looking pretty damn good, Ian. I mean the whole set-up, color, yellow rollbar, honeycombs, Porsche crest, jeez man... akeeper. Thanks for posting, good inspiration (and motivation!)
Originally Posted by BRAN
if the plastic is as good as the OEM and the brakelight add-on just optional (turn off/on)...
then count me in as well.
Nope, not as good; ITS TEN TIME BETTER!!! Literally optic-quality clear, no defect, same material (pmma) and professionally coated (scratch/chemical resist). Not all that bad, Bran
The brake feature is optional of course, just omit the extra connection.
Our SkyBreaker Club so far:
TTGator, robdelorenzo, Kboggs, Dubaday, maytag, bg305, Troy.Boxster, rick3000, Bran, Jeffrey
*Update*
I've seen that our RGB Led PCB mfg was completed today so once we receive this (late weekend?) we'll be able to prototype on the micro and get drivers working. Also ordered ICs for the driver, we'll try the TI's TLC59731 (single-wire driver) and a ULN2003 Darlington transistor arrays. We are dealing with common anode leds here so not exactly sure who will win the switching job, let's see when we get the parts.
Once we have the RGB and Brightness circuit all dialed-in, we'll move on to an input for the brake signal and wrap this for the electronic part of the upgrade. Should be easy, not!
^ If only I could learn to be as efficient as these guys. They wrap-up hundreds of completed pcb in-a-day these chaps, go figure :/
