Old 01-10-2020, 03:54 AM   #6
piper6909
piper6909's Avatar
Originally Posted by Porsche54321 View Post
It looks fine could it be the ignition switch ?
I guess it's possible, but in my case with the exact same symptoms it was the immobilizer.
You believe water infiltration caused it, how much water did you get in? Any puddling at all on the floor?
It's possible you got water on the immobilizer, but it hadn't corroded yet. If it got wet at all, it may still be wet under the relays where you can't see it.
If you suspect it got wet or damp at all, douse it with rubbing alcohol to displace the water and then let it dry out thoroughly.
piper6909 is online now   Reply With Quote
