Old 01-07-2020, 11:45 AM   #11
AZ986S
AZ986S's Avatar
Originally Posted by Blue99 View Post
Hi. Get a fuel pressure gauge connect it to the valve on the fuel line and check pressure
Just because fuel is pumping does not mean it has pressure the injectors need a min pressure to function don’t throw money at it start at the basics.
+1
Check fuel pressure 1rst
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
