Old 01-04-2020, 12:37 PM   #13
blue62
Originally Posted by seanboxster View Post
That's a great idea thank you.
At this point though I'm afraid that I'm running in circles to avoid the answer of a fried computer or wire harness etc.
Well I am trying to guide you down a logical path and keep you from running in circles
Try the test I outlined (spraying gas into the intake while cranking the engine).
Let me know the results. Then I will have an idea of which test to do next and which direction to guide you.
Most mechanical issues are relatively simple. But one needs to diagnose them in as logical and linear a fashion as his knowledge and ability allow.
Go from the simplest to the most complex step by step.
So with that in mind and with the test I outlined. I am attempting to determine if you have a fuel delivery issue or an ignition issue.
Once that is determined it gives us a linear direction to go.
