Old 01-04-2020, 07:04 AM   #11
titaniumdave
I have had too many projects on my plate, NSX race car build, 2 Lotus Elise builds and back surgery for a ruptured disc...good by 2019! It’s 2020 and I’m finally picking this back up. Sorry for the delay but we are finally making a small batch of the cradles. They are a direct bolt up for race car set up where you can do some cutting to get the throttle body to fit and you are not running the AC compressor. If you are doing a street application you will need to do a work around for final fit up. Cost is $980 with fasteners if you get in on this first batch. Message me if you want to get in on this, they will be duplicates of what I have been posting, very much geared toward track/race application, transmission is in the OEM location, front of the motor has been dropped 50 mm to make clearance fo the heads under the OEM cover with only minor massaging. Plan is to make 3 right now but I can add to that if folks come in right away. Delivery will be end of February.
titaniumdave is offline   Reply With Quote
