Like said above, check the O2 sensor and definitely look for any vacuum leaks or a failed AOS or hose. There is a good chance you may have puked some oil from the AOS into the intake on that hard U-Turn which was ingested on bank 2 and fouled that side. Pull your throttle body and look for excessive oil and recheck the coil packs and plugs. A failed scavenge pump can cause those same codes, but that's bad... really bad and will be evident if you check the timing marks and they are off or pull the sump and find pieces of the drive gear. Eliminate the simple stuff first before throwing parts at her. Fuel? Spark? Air? Go from there.
