Hi Lacostas, did you get anywhere with this?
I have a similar issue in the fact that I can only open the car intermittently with the button, probably due to circuit board as noted in other posts. However I have the same problem when opening with the key.
When i use the key it only opens the drivers door, the fuel flap and passenger door stay locked and I can't open them with the button on the dash.
The only way I can get round it is, put the key in the ignition turn it to auxiliary, turn it off remove the key and put it back in the drivers door and turn it to open, then it unlocks the fuel flap and passenger door. Its almost as if when I lock the car then come back later to unlock it is loosing it's sync.
Just a bit annoying to keep doing that every time I unlock the car.
Could this be an immobiliser issue as PW suggested?
Steve
_________________________
2004 Boxster 2.7 - Atlas Grey
