Old 12-30-2019, 07:36 PM   #21
LAP1DOUG
LAP1DOUG's Avatar
Originally Posted by Hasbro View Post
Fwiw, was comfortable with 2.35 - 2.5 hz. suspension and RA1s on last street project, could go a little bit higher with proper dampers.
Hasbro:
With the low weight that you are going to, you are looking at a corner weight of about 540 lb on each front wheel, and 660 lb on each rear wheel.
With these corner weights on the 986 suspension geometry, you only need about 330 lb/in springs in front for a 2.40 Hz frequency, and 430 lb/in rear springs for a 2.56 Hz frequency in the rear.
If you are going to autocross at AMS, I would not go much over a 2.5 Hz frequency as there are some surface changes where you need compliance to avoid upsetting the balance.
If you know what natural frequency you are going to run, you really don't need multi adjustable dampers. Just get some high quality single adjustable dampers set up at around 70% of critical damping force, and you are good to go.
That said, the biggest bang for your buck is going to be camber control. For that, you need either GT3 LCA's or camber plates (or both) along with an adjustable front bar. These McStrut suspensions have awful camber curves, and you must add front bar to stop the dynamic camber change that makes the stock configuration understeer like a pig.
Good luck.
Kippis
986S
991S
Van Diemen RF97
LAP1DOUG is offline   Reply With Quote
