Old 12-29-2019, 05:58 PM   #10
AZ986S
AZ986S's Avatar
I bought this car a couple weeks ago.
I pulled the motor. Oil pump looks ok. I'll likely use the heads from this motor and rebuild my other 3.2 with them.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
