Need a broken or badly burned headlight
I'm playing with LED headlight bulbs and need a 986 headlight housing for testing. It does not need to be in good shape as I only need the rear section to use for testing the fit of different LED bulbs.
There are several different heatsinks used on the rear of LED bulbs and I'm checking which ones will fit inside the 986 headlight enclosures and how much heat they produce inside the enclosure with the cover installed. Anyone got a badly burned or broken headlight assemble they want to get rid of?
1998 Boxster
1991 Carrera
