Old 12-23-2019, 09:25 AM   #2
derfo
Cool AOS oil leak
I had a similar problem. The tube at the bottom of the AOS had become loose at the engine block allowing some oil to drip. I simply cleaned the area and re-attached the tube properly. No drips since then.
Thanks for the advice thstone. I put the car on the ramps today and had a go at tightening up the jubilee clip. I was able to tighten it up a few turns. After that I dried everything of, so I will have another look in a couple of days to see if I have stopped the leak.
derfo is offline   Reply With Quote
