Originally Posted by KMikkelsen
Nice mod with the Toth spoiler.
I have it at home as well, but haven't mounted it due to the fact that you have mentioned.
So your solution is absolutely the same that I am going for
Thanks for the inspiration!
Hi K, you’re welcome! Not sure this mounting method will work on the gen 1 Thoth spoiler but I’m please with it for the gen 2.
Some additional points on the mounting. My clearance between the spoiler and trunk lid was too tight for the screw heads when the spoiler was up. I was able to grind down the stainless steel screw heads, retaining enough material to still be able to securely tighten the screws. I didn’t want to counter sink the the front screws because I wanted to retain as much of the spoiler material as possible.
For the underside rear edge I was screwing directly into the fiberglass so I used coarse thread screws, was really careful not to over tighten them and put a dab of clear acrylic on the screw heads. The front screws really do most of the work securing the spoiler and the bottom screws mostly snug it up so it should be ok for the long haul. I’ll keep an eye on it and mod in some threaded inserts or something if needed.
Rgds, Fred
