Hi Javi, yes your org pic is the complete aerokit 2 package. If you locate a set you’ll also need to get the underbody clips to attach the lower edge. I have the clip part number around somewhere. Let me know if you need it.
I tried two different sets of fiberglass replicas (techart and hofele copies) before deciding to go with used oem aerokit 1. No comparison for fit and finish between the oem polyurethane skirts vs the fiberglass copies.
The aerokit 2 fairs better as takeoffs than the aerokit 1 because of the way the aerokit 1 attaches to the car (really meant to be permanent while aerokit 2 uses two sided tape on the upper edge).
Good luck with your search!
Rgds, Fred
