Old 12-17-2019, 10:19 PM   #30
elgyqc
elgyqc's Avatar
From the photo it looks like there is one broken bolt... the 5 others must have backed out and the last one broke. The flange near what I take to be a broken bolt is messed up as if the shaft was banging around in that area before the bolt broke. If the threads in the bolt holes are OK and if the flange does not prevent the shaft from properly seating you may be able to put it back together with NEW bolts and be on your way.
Grant
