on some 986's if you remove the airbag bar you have to get the CPU uncoded , this is a safety check by the car to ensure the installed bar is working
Not all 986's had it, on some you could remove the bar without incident
To test ... unplug the bar and start the car, if the airbag light stays on then either you need to keep the bar connected or uncode the CPU
If it goes out then happy days
