Old 12-14-2019, 04:01 PM   #36
outsidetheboxster
Hi All
Made my first mistake I can't fix on my own. (Thought that might get your attention.)
Moved parking brake crank assembly and got it all tidied up and workable. Same location but 2" forward from stock. Easy fit! Went to drop the body over the engine one final time and bolt it all in. Got the rear mounts in and went to the front only to discover the strange sound I had heard while lowering the lift was the drivers side cable getting caught on top of the head and stretching it out. Added about 3" of length and unraveled a bunch of housing. Found and ordered a used cable on the E-site. Should be here in a week.
If that's my worst issue I'll be happy! Getting closer to an initial start every time I work on it. Next is wiring and fuel lines. Still moving along and hoping to have it motivating under it's own power in the spring.
Cheers!
outsidetheboxster is offline   Reply With Quote
