I am new as well so take everything in the context of that knowledge..
Originally Posted by monopola
So, me again with a looooots of questions 😊
1. Initial servicing – anything tricky with that? I will replace oil, fluids, filters, brakes and so and I will appreciate recommendations on anything else I should take care of. Tried searching the forum for a simple “what to do” as initial service, but was not able to find such tread.
I did my own oil.. you need a new crush washer before you put the plug back or it will leak. 9qts of mobile 1. I inspected the oil for any debris and ripped open the old filter to see what was caught in it. Found absolutely nothing which made me feel better about #6 below.
I also cleared out the water drains you don't want a wet immobilizer.
I am going to do plugs over the winder and inspect the coil packs when I do. Not planning on replacing them unless they are cracked.
I also purchased a good scantool for reading / resetting porsche ECM and other systems. I have a feeling this will be a worthwhile investment.
2. Biggest issue with the car yet – the top. You can see in the images that there is one broken “leg”, which is part of the top mechanism, but also it is missing some parts. Also, I have this long cable under the wheel, which I suppose should be
connected with the top’s motor. Any ideas what I should be looking for?
I know you can any there as a part (albeit expensive) from porsche. Most everything I have touched on the car has a part number stamped on it. Usually starts with a 986 or 996 if it works for both cars.
3. Passenger air bag – looks like the cover is not for the same model as it appears not to be fixed as it should be. Is this possible or do you think that I should just push it harder?
Not sure.. careful messing with the airbag. It definitely looks different then my 01 S. Are you sure it is an airbag? Almost looks like a "filler" for the spot. Any airbag markings on it?
4. Wheel – I am not sure that this is original wheel for the car. And also looks like that the airbag was open somewhen as the center of the wheel feels cracked. What do you think – should I look for new wheel or at least for new airbag?
Does not look like my 3 spoke. Airbag looks right.
5. Ignition – there is this problem – when I turn the key to start the car the key should turn back a little. Mine doesn’t always do that and the car is working, but the wipes and lights are not. When I manually turn It back it is all good. Maybe I should replace the ignition.
I know some have mentioned a "hard to turn" ignition. Seems to be a common issue but not one I have had. Do a search, you should see some ideas.
6. IMS bearing – guys, what is this ☹ I am a lawyer and English is not my native language, so could someone explain it very simple – should I be worried, should I replace it and if so where to buy it?
This one everyone has an opinion on. I think you will just have to try to read up as best you can and form your own. Lot's of people say if it has not blown by now you are likely fine. Check the oil, enjoy it, and when you change the clutch, address it then (and then there are many options when doing so). It made me feel better when I saw my filter that was in the whole year and drove at least 4k with the oil in there was perfectly clean. My car has 51k miles, when it needs it first clutch I will do something.
7. Interior parts – I am missing some of them or need to replace (covers on the sensor near the mirror, ashtray is not working, the key for the armrest, the light inside should be replaced, the center console disk holder is useless). Should I be looking in ebay and pelican parts? Any other sources for such small things?
Occasionally you might see a thread pop up with parts cars, I do not know about the shipping to your country and if that will present an issue. You can get new parts but they are super expensive and will add up quick. I would find ways to get alerted if any parts cars show up near you and grab as much as you can. Otherwise, ebay, of course..
8. The box behind seats – I have seen cars with a nice box, which is mounted behind the seats. What is the name of this thing in English and any idea where to buy it from?
You mean:
https://www.pelicanparts.com/More_Info/98655122300EMY.htm?pn=986-551-223-00-EMY-OEM&gclid=CjwKCAiAis3vBRBdEiwAHXB29Jn2-t1sgLmvpu40t26ArxvHiJo5B-AraSHZJXrnWwp0CrxtdIHMnhoCjnwQAvD_BwE
Best of luck finding what you need!
