I replaced the original soft top on my 98 with a glass rear window version. The roll bar gets in the way of the glass window when you open into the service position. As a result you don't have as much room to work on the top of the engine as you do when the soft window is pulled all the way up into the service position. That said, I have not found it to be a major issue but more of an annoyance.
Having a rear window that I can see thru and rear defroster is a major plus! And not having to do the chop is nice too!
1998 Boxster
1991 Carrera
