I believe there are 2 emission control valves that vent to the whole under the gas filler door.When i replaced mine i was worried that the one i replaced might be the wrong one....but it fixed it. in your case you might have not replaced the one causing the noise. the issue is exactly as you describe. blowing over a coke bottle sound coming out of the whole under the gas filler door.
