sounds like the issue is elsewhere. If you can confirm that the fluid system pressure is normal (not sure how), then it might be that you have a bad pressure plate or issues with the throwout bearing or arm it resides on. I haven't heard much about master cylinder failures but is suppose if something is wrong there it could cause problems.
Does the clutch disengage smoohtly/easily?
