Old 11-25-2019, 09:10 AM   #1
The Radium King
The Radium King's Avatar
Probably front has holes and options for adjusting castor while rear has a single hole in center. They are the same otherwise.
ah, good catch. i'd assumed they were all adjustable, but if you re-read perhaps not. why would you not get adjustable caster option on the back - with 20mm shims on the back you could run 996 rears but would need to adjust caster to address.
https://www.tarett.com/items/986-987-981-718-products/986-987-981-718-suspension/986-987-981-718-monballs~bushings-/adjustable-thrust-arm-bushing-kit-tabka01-detail.htm
