Old 11-25-2019, 05:46 AM   #21
ksjohn
ksjohn's Avatar
I have a 3.4 996 with 278hp at the wheels in my boxster. It's fun but not enough for me. Most oil leaks on the 2.7 are the oil lines connected to the turbos. It's highly unlikely you'd keep those small KO3's when installing that motor into a boxster anyway. I have a 2.7t waiting to be put in my boxster but I plan on going with a single turbo. Guys are getting 700hp+ out of those 2.7t's. I'm shooting for a more reliable 500hp. I'm not sure the suspension could handle more than that. I also plan on using a cayman 6 speed to make the swap easier. The mechanical part of the swap looks to be very easy. Electrical, now that's a different story.
Hi Woody, thanks for the info!
Ideally I would like to keep the twin turbos. But then I need to learn a lot more about turbo powered engines, pros and cons....
I was reading a long thread about a guy in England I believe. He did install a 2.7 with both turbos in his Box. He had several issues with working out an intercooler and the air supply piping. But he was also working on a very tight budget in a carport which probably didn't help much. I agree, the electronics will be my biggest struggle as well.
ksjohn is offline   Reply With Quote
