Old 11-24-2019, 11:11 AM   #10
Racer Boy
Racer Boy
Racer Boy's Avatar
Originally Posted by Fiddlebog View Post
This happened to my passenger door. turned out the connector to the latch (the 10-pin one) was making bad contact. Replaced the connector, fixed the problem.
I've never heard of anybody else having this solution, though.
Try wiggling that plug while the door is open. When I did this, it caused the window to go up and down and the horn to beep at me (this connector also tells the car whether that door is closed/locked), which is how I diagnosed the problem.
Originally Posted by PorscheBear86 View Post
Holy **************** thats exactly whats its doing it was like shorting out when i was replacing it! window was going crazy and the horn too! I unhooked the battery at that point and figured it was the micro switch shorting out. Thanks for your help! How did you get that new connector? (10pin one)
My car had those exact symptoms, but replacing the latch assembly fix the issue.
